I would start by taking a picture of things if you haven't already. That way you have a reference to look at if you can't remember or need a guide.
As Ponky mentioned, the ESC powers everything in the truck. I would start by unplugging the servo (Channel 1) and trying to power the truck on. Make sure the transmitter batteries are good too if you can't remember the last time you changed them.
So plug a battery in with the transmitter on and see if the ESC and receiver power up properly.
The model should now move forward and backwards.
If that is not the case, it has been narrowed down to the receiver, transmitter, ESC or motor.
There are a few paths to take;
- You could try swapping things out.
As mentioned a new motor and esc combo can be had pretty cheap.
- Second, you find a reputable shop in your area if you don't have a friend who can help you out.
When troubleshooting it is extremely helpful to have other known electronics around you can swap in and out to narrow down failed components.
As someone mentioned, the 2075 servo COULD be a problem but honestly anything could be going on.
Your description of audible sounds of shorting would lead me to believe it's either the motor or ESC.
A component could have been exposed to moisture and shorted or overheated on your last run; we just don't have enough information.
Please let us know if we can be of any more assistance with your Slash.
