I see more MMXs in my future. I wonder if the RX8 has data logging?Not all of them do it, but the higher end ones do, like the MX, MMX, XL2, MMX8S all do. Probably are others as well.
I mean no one really knows for sure what an EC5 is rated at either so I'm not sure it makes a lot of difference but I get it.BTW if a manufacturer doesn't provide specs for a connector they can keep it. That's my attitude with close architecture of anything. I put EC5 on everything no need hassle with connectors at all.
you're going to get a million different answers to this question.
I'm not saying theres anything wrong with EC5, in fact I think those and XT90s are great even though I'm still hung up on Deans connectors personally. I can show you 3 different manufacturers right now who all say their EC5 connectors are all different amp ratings. One says 50A, One says 60A, and one says 90A. So just like Deans no one really knows what the true rating is on EC5s either. I'm betting if I went looking I could find the same discrepancy in XT connectors too.dunno read it somewhere maybe google it. think 120 continuous and 150 max, couldn't find any better connectors so I settled on ec5 haven't been disappointed.
Thats my point though. All the Amp rating on everything regardless whether its connectors, escs, lipos etc are all blown way out of proportion and when it comes to connectors its even worse because different manufacturers are claiming different numbers for the same connectors. Just like Olds97's earlier data logging shows on his 6S Maxx the average Amp draw is only about 25Amps. It had spikes as high as 91A but these spikes are literally very quick and most connectors or even electronics can handle short burst of really high amperage pretty easily. Its the continuous draw thats the most important thing.The product description on these ec5 sold on amazon is 100 amps. These are the ones I got. Scroll down to product description where it says 100 amps. However, who knows for sure. castle log shows as much as 200 amps but that a very short peek. Like I said haven't had any problems with connectors. Had problems with everything else though lol
https://www.amazon.com/Connector-Fe...nectors+150+amp+rating&qid=1623560030&sr=8-15
Was a little worse today. I think I left it running for a decent chunk of time early on because I was working on it, so that kind of screws up the average. If I just highlighted the busy section on the right, the average was 32A or so.Thats my point though. All the Amp rating on everything regardless whether its connectors, escs, lipos etc are all blown way out of proportion and when it comes to connectors its even worse because different manufacturers are claiming different numbers for the same connectors. Just like Olds97's earlier data logging shows on his 6S Maxx the average Amp draw is only about 25Amps. It had spikes as high as 91A but these spikes are literally very quick and most connectors or even electronics can handle short burst of really high amperage pretty easily. Its the continuous draw thats the most important thing.
I agree with the Dean's comment, I race 1/8 buggy/truggy with Dean's on 4S, the connectors were the least of my worries. I can see why the 6-8S basher might go bigger, but I'm pretty happy with Dean's on 2-4S. That said, more and more I find myself using XT60, for no other reason than availability. I will admit, soldering XT60 is a bit easier than Dean's and the connectors are easier to connect/disconnect.I'm not saying theres anything wrong with EC5, in fact I think those and XT90s are great even though I'm still hung up on Deans connectors personally. I can show you 3 different manufacturers right now who all say their EC5 connectors are all different amp ratings. One says 50A, One says 60A, and one says 90A. So just like Deans no one really knows what the true rating is on EC5s either. I'm betting if I went looking I could find the same discrepancy in XT connectors too.
thats pretty sweet!I was just thinking the SAME thing!!! That looks like a Dyno Log from when I was getting my car's engine tuned!!! That is AWESOME!
Depends. Just because a motor is capable of drawing 100A doesn't mean it will (read as gearing can make all the difference) but it it was pulling 100A continuous then youd probably fry your ESC. If your ESC could handle 100A continuous then youd end up melting either your connector or your wire, whichever is the weakest link.So if the esc/wire/connector was rated for 60 amps and 75 burst and the motor was rated for max amps of 100 would the esc/wire/connector be bottle necking the motors power?
Just depends on what your doing. Like with my maxx4s, I run a castle mmx/2200kv 1515 in it on 6S. Average amps used isn't that high, but there are a lot of spikes above 50amps with a peak of 98amps. Well, at least during my last run:I just use deans for everything, I don't know what they're rated for but I like them a lot, if they would ever burn through, I would just change them out.
