Axial SCX24 - Tire Wobble/Servo Help
PewPewChris
Georgia, USA
  3. Crawling
  4. Scale Builder
  5. Flying
I love the upgrades I've done to my wagon thus far...but I must have bent the pin/steel rod in the front axle as the front-right tire wobbles. I switched tires around to make sure it wasn't the tire itself...it isn't.
I can't seem to find that pin as a single replacement part...am I going to have to buy a whole new front axle?
I also need some help getting my steering corrected, thing hardly wants to turn right...
Nope, I'm just a noob and using the wrong verbiage.
I don't know how you could bend that pin on an SCX24. Are you sure your axle isn't bent?
I'm just using wrong terms...I call it a pin...it's the axle I assume, when I "think" axle, I think of the entire axle casing...it's the metal pin/rod extending from the differential to the wheel...and yes, fairly confident I bent it somehow.
You'll need to figure out which part you really need first.
I believe the complete axles are all the same but verify it. The parts diagrams are available on Amain. Just pick your specific model and you can find the part numbers.
https://www.amainhobbies.com/axial-scx24-parts/c15444
For Axial branded parts, they only sell the complete axles and they are about $25/$28; however, there aftermarket parts.
This link is for SCX24 parts and I narrowed it to just thinks with "Axle" in the name. If you can figure out what is broken, there might be aftermarket options.
https://www.amainhobbies.com/hot-ra...f39w04-hrasxtf39wf/p1329603#tab-compatibility
I would find the parts manual online if you don't have it and find the part number of what is bent.
There's a ton of aftermarket parts out there.
I use rpphobby . Take a look around there, they usually have all kinds of parts.
I'm thinking it's the axle you are looking for.
it's gotta be the axle that is bent...I was calling it a pin because of the size and it is inside the axle casing...I'll get one on order...looks like I need a few other things as well for some other broken trucks lo, ehich is the case the axle goes into that you are referring to.
Yeah, that is the actual axle. Then you have the axle housing. You can buy them on Amazon pretty cheap. But look at the reviews.
