So on my first run my rear suspension arm snapped in half. I disconnected all the suspension components from what was left of the suspension arm so I could replace the suspension arm, but I’m stuck on what I believe to be the rear suspension mount that holds the “hinge pin” that keeps the suspension arm mounted to the frame. How do I remove this thing?
The problem I’m having is that it appears to not only be fixed to the hinge pins of the suspension, but also to the BOTTOM of the frame with a little block that comes down through the bottom of the chassis, making it almost impossible to pry any direction since its mounted in a way that prevents movement from just about every axis (yes I have removed the two screws that appear to keep it in place)
If this isn’t even how you remove the suspension arm of theres an easier way let me know, I’m a total noob so I don’t really know what I’m doing
