Airtronics M8 questions
Tony6289
I recently purchased a new old stock M8 radio and it has 2.4ghz module 93724 but did not come with receiver. I purchased a receiver 92724 online and I can’t get it to pair and I think there is a problem with the receiver. I’m looking for another one that will work that is three channels. Thank everyone in advance for any help. Tony
The M8 with that module .Oh it brings back memories or should I say nightmares.. had same issue as you but that was back when both where state of the art.. some worked others nope..If possible send it back...Unsure it spectrum DSSS worked ..I think they did ones with green bind button on rx..although I've had clean running radio when others have run aways .lose connection at 100'..still love my radiopost ts 401.2. hated when cheap brands flooded the market.. Nothing like a Helious ex10..with a drop down.n 1/16 scale rear tire as grip.....
I've had the Airtronics M11 since it was FM and then converted with the module to 2.4. Lots of cars, trucks and 1/5 scale bikes programmed into it without a problem.
Can you help me figure out what is going on with mine.
This is the one I have and I am looking for a 3 channel receiver that will work with it to run my MGT 8.0
I can't tell by your pics but you'll need to put in the info that's on that module and do a search for the compatible receiver.
Module in radio is 93724. I don’t know enough about what receiver will work with it. I bought a 92724 receiver. but it seems to be bad light does not respond when pushing button. Either need to find a module that will work with receiver or need to find receiver that will work with existing module. I am from crystals era and I don’t know enough to figure this out. And direction would be appreciated. Thank you.
This SEEMS to be the one that's compatible with your module but just to be on the safe side I'd call a local hobby shop or Hobbytown USA just to have them verify it.
Do you know what forum I might find someone that my be selling a module for my m8 radio and receiver. Thank you
You can do a search through google or go to eBay or Craig's list. You could also see if your local hobby shop can order it if they don't have it in stock.
X
9
xxtcrageless
X
C
9
CrunchyM5k
C
ymft81
20
Finesavageboy2
Finesavageboy2
G
3
1K
Bigfoot3387
Bigfoot3387
