Abnormal throttle signal Team Associated Pro SC10
I have A Team Associated Pro SC10 owner's manual said when your Esc does not detect a normal throttle signal the LED will Flash this is what it is doing but I don't know what the solution is to fix this when you turn the truck on the green LED just flashes and it won't turn it won't go forward or reverse or anyting any help would be appreciated
The receiver is probably bad an the ESC is not recognizing the receiver signal ,or
the rec. needs rebinded to the transmitter!
I had this happened on a Traxxas TQi because of a damaged receiver antenna!.. :cool:
hey guys, so I bought a pro sc10 about a year ago
Having a very very similar problem
Green light just blinks rapidly and nothing on car works. Steering, nothing
What I’ve done so far
-tried rebinding old receiver after it broke nothing.
-went on and bought new receiver, ESC and motor
-connected new esc and receiver to old motor and rebinded controller (everything seemed fixed after some tinkering. Took the car out and in about 5 minutes the car stopped and had the same issue.
-I’ve had people say I should’ve connected all new equipment up instead of trying to use old motor with new esc and receiver. (Which I now agree was probably the reason it stopped working)
So my big question is…could I have burned out my new esc with my old motor? I plan on putting the new motor in and trying to rebind again. What coarse of action would you guys take?
Really appreciate you guys if you can help!!! Just wanna play with my RC!
Sounds weird, but a bad servo can make your receiver go bananas. Unplug it from the receiver and see if you then have normal motor control. There‘s no difference at all or any problem with connecting any combination of new components to old ones that are still functioning properly. And of course make sure your ESC is set up for LiPo’s, not NiMH’s, if that’s what you’re running. Or vice versa.
And verify your servo is in position 1 and the ESC is in position 2 on the receiver. Rule of thumb, “1 to turn, 2 to burn!” The black wires on the servo wires and ESC wires plug in and go on the outside of the receiver. Check that too.
