If you have a 4WD monster truck with four motors and the front axles do not turn then how does the vehicle turn? For example, if you are going forward and you want to turn right, which motors are running and which direction? I assume that going forward the at least the rear two motors are turning in the forward direction. When turning right, does the front passenger side motor turn in the reverse direction to pull the truck to the right? Another question is with a 4WD truck shouldn't all the wheel be tuning all the time in at least one direction?
