3PK radio set up
ferrous
RCTalk Qualifier
Albany, NY
I'm using the 3PK with my mini-revo and I was hoping you guys could tell me if I set it up properly. First I set all the trims to 100%, then aligned the front wheels with the steering sub-trim, then I set the left and right steering endpoints. Is that all I need to do? Did I miss anything? When I turn the wheel to full lock in either direction the servo is silent. That's good, right?
I also reprogrammed the ESC to allow for the longer throttle pull/shorter brake throw.
I'm guessing that you meant you set all of your trims to "center" rather than "100%". I'd say you are good to go though. :thumbup:
Yep, that's what I meant. I must of had the vision of the endpoints screen in my head instead of the trim adjustment. That's what happens when you try to recall the previous nights hobby work the following day at work work. :\
