If you are having problems finding front A arms for your 4x4use a rear off a 2wd. Cut the cross brace out fo the end closest to the hub carrier so it will clear are the c hub and drill behind it for 4/40 rod put the rod in with 2 nuts and bingo back into buisness. Hope this helps
