27mhz to 2.4ghz conversion??
I have a feeling it may be the shocks as the car is very springy. Shocks are original just a doing with a piston no oil fill or adjustment but can’t seem to find any oil filled shakes the correct length. The ones on it are 62mm eye to eye centre.
If you take your truck an set it on blocks or up in the air with wheels of the ground ,you can see
if the axle is wanting to pop out of its cup that comes out of the diff ,on quality RC's ,there is a set
screw on the a-arm to adjust ride height an droop ,that helps with that problem!..😎
Had a check and the seem to be sitting well in their cups. I have no height adjustment as it’s fixed
