The company I got mine from I think is a german company or some other language, because the manual was translated (badly) from some other language. So, no, it does not list the settings. I think I might have gotten into 2 gear the other day, but it could have been air in the fuel line. Which way do I turn the screw on the gears to make it shift at a lower speed? I know it may seem strange, but so am I, so I think it sounds cool when it shifts. (lol)
Yes, I have completed, or at least mostly, the break in process (running at idle for 5 tanks, then driving slowly for another 5, then medium speeds and so on is what I did, with help from my nitro expert neighbor) but it could also be that I need to re-tune the engine. The manual is not very clear as to which way to turn the high end and idle screws in order to make it lean/rich.
That said, can you also give me advice on which way to turn the screw? Right now, it idles smoothly (well, if it's supposed to sound like an idling weed eater) for about 10 or so seconds but stalls after that, is it supposed to idle for a while or is it normal to stall in idle? After going full speed, it does not stall (usually, occasionally it might stall at the exact opposite end of the street from me :sneaky: ). Also, I have to slightly trim open the throttle to start it, is this normal, the throttle is set with about .7 mm of air space when closed so I might need to open it a bit.
Wow, long post, huh?
