First, I apologize for my noob question and I appreciate anyone who can assist me.
I'm a bit of a hack tinkerer and decided to re-purpose a cheap 2.4G, 1:40, 4CH "stunt" car from Taiyo.
The car is 4CH but doesn't have a steering axle. So when you press RIGHT or LEFT the car just spins on the spot.
If you press R or L while you're pressing UP, the car jerks to either side and or just starts spinning on the spot.
I opened it up and found 2 small motors, small rechargeable battery and of course the receiver board with connections that read L/R and F/B (I assume LEFT, RIGHT, FRONT, BACK).
I figured this should be simple, L/R is for steering and would get activated when I press LEFT or RIGHT on the stick. And same would apply for F/B when I press UP or DOWN.
This is where the madness started.
Here are the button combos and what they do with Motor A on F/B and Motor B on R/L
UP = Motor A (ON), Motor B (ON)
UP + LEFT = Motor A (ON), Motor B (OFF)
UP + RIGHT = Motor A (OFF), Motor B (ON)
I removed both motors and started playing around with it by moving the wires around in different combinations to achieve a typical RC car setup where all directions work independently from one another as well as together.
I found that I can get both motors working independently when I attach a motor to F+L and one to R+B but they don't work well together.
Pressing UP works but then pressing RIGHT at the same time stops the F/B motor and starts the R/L motor.
I'm probably over complicating my situation, but has anyone dealt with this type of configuration and is it possible to reconfigure it so I can place it into a regular RC chassis with proper steering?
Thank you!
Thank you!
