Today I went to install a RC Solutions cage on my LST. Should have been a simple 1/2 hour install right. Wrong, thanks to some jackhole at Losi. The RC Solutions design calls for replacing the center skid, easy enough, just remove a few screws. Now for some reason, Losi decides to use tiny ass screws all over the LST which use a 1/16" hex driver. Not really a problem when threaded into plastic. Thread locked into aluminum is a different story. There were 2 screws on the center skid that threaded into an aluminum brace and they were not moving. I broke off 4 drivers trying to remove these 2 screws. They are not cheap drivers either. One was from my Losi set. Why the hell did they use 1/16" hex screws. The drivers for them are just too thin. I can actually see them twist before breaking.
I ended up drilling out the 2 screws and ruining the brace. Its a $5 part so I just figured I would remove it and replace it. Guess what, its secured to the chassis plate with 4 more of those pissant screws. All locked solid. I managed to actually remove one and the threadlock on the screw has a red tint to it.
Losi, you suck.
Here is the damage tally:
Chassis Brace: $4.95
Center Skid: $8.00
1/16" bit for my Losi Driver: $6.95
Getting pissed-off and frustratad: Priceless
And I still have 3 screws to remove. So much for getting the cage installed today.
Losi, you suck.
Center Skid: $8.00
