The new XRAY NT1 brass engine mount has been designed for all conditions. The XRAY NT1 brass engine mount provides a stiffer design than the standard single engine mounts but is still a bit more flexible than the XRAY Multi-Flex 1-Piece Engine Mounting System (#338712). The engine area of the car and the area between engine and 2-speed is reinforced but the flex of the chassis is still available. The reinforced area of the chassis between the engine and 2-speed gears reduces the chance of spur gear breakage or stripping.
The XRAY NT1 brass engine mount is CNC-machined from premium brass material. Precision machined with highest tolerances using premium fully-automatic German CNC-machines. Ultra-strong construction provides very long life and durability in even the most extreme racing conditions. The weight of the XRAY NT1 brass engine mount is 53.5g and is heavier by 26g then standard engine mount. Thanks to this extra weight, the XRAY NT1 has more in-corner steering and not so much extra weight is needed.
XRAY NT1 brass engine mount features
- Solid engine mounting
- Easy adjustment
- Stiffer design yet more flexible than the Multi-Flex 1-Piece Engine Mounting System (#338712)
- Reduced chance of spur gear breakage/stripping
- CNC-machined from premium brass material
- Precision machined with highest tolerances
- Ultra-strong construction provides very long life and durability in even the most extreme racing conditions
- Brass material is heavier by 26g then standard monoblock
- More in-corner steering
Part #: 338716 – XRAY NT1 Brass one piece engine mount
