The crankshaft locking tool is a piece of Delrin or engineering plastic that is about the size of your wife's pocketrocket. It is inserted into the back of the engine where the connecting rod connects to the crankshaft. The plastic dowel if you will, has a slot machined into it. This slot holds the con rod from spinning by taking up the slack in the crankcase. I hope that makes sense, it is kind of hard to explain. Most of these tools, like my O.S. model have two different slots on each end of the plastic dowel to accept different size engines. My tool is designed for .15 thru .21 if I remember correctly. Hope this helps you OLDS 97
