Hello, i was just wondering if anybody knows the instructions on how to break the XTM 24.7 motor in. i had purchased mine from ebay and the guy didnt send me the instructions!!
Check you lsn and hsn first. lsn should be at 7.5 turns out and the hsn should be 4 turns out. use a hot plug for breaking in the engine. These engines are very tight so crack open the glow pulg a little bit. then when it starts running tighten it back up. I let mine idel thru 4 tanks with the wheels barly moving. then 2 tanks with short bursts on the ground. after a total of 10 tanks I leand mine out. I did not see the true performance of the engine until 1+ galon of fuel. If you have any more questions please ask.
I wouldn't recommend just idling your tank. Set the needles to 4 turns out on the hsn and 7 turns out on the lsn.
Tank 1-Blip the throttle and gently brake for about 3 mins. Don't go above quarter throttle. Shut off the engine and let it completely cool with the piston at BDC. Continue this process until the 1st tank is almost empty.
Tank 2-Lean out the hsn just a little. About an hour on a clock. Go up to half throttle. After tank is almost empty, shut it off and completely cool at BDC.
Tank 3-Same as previous but, lean out hsn a little more. Also go to about 3/4 throttle.
Tank 4-6- Same as previous and lean out the HSN after every tank. Just make sure you get good smoke and keep the temps down. You're going to want run below 270.
Tank 7- Tune for performance.
Tip: Whenever you cool the motor during break in always make sure the piston is at BDC.
yeah so far my truck is awsome. i am just having a few problems with my clutch shoes and my CVD's that came with the XTM .21 conversion kit. i forgot to put some thread locker in them and now they are all lose. also about the clutch shoes will it make my truck go in and out of nuetral?
