Xmaxx toe link hitting suspension arm
Pablo1980
RCTalk Rookie
Uk
Hi, was using my xmaxx the other day and noticed a knocking noise when I turned hard left and after having a look I noticed the toe link is hitting the suspension arm on full lock turning left. I've tried adjusting the end points but not having much luck. Turning right isn't a problem. Hope someone will have some ideas what could be causing this also the toe link is fairly new
As you can see the toe link is hitting the suspension arm but when I turn it right the toe link seems to be lower than the suspension arm and a gap between them. It seems to be too high compared to the right side
It's kind of hard to see what's going on there, have you set your endpoints on your transmitter?
I looked at mine and there not close at all.
I tried that earlier, when I get time tomorrow I will take a pic of the other side to compare
Sorry I haven't been back, I tried to set the end points yesterday with no luck by next port of call is the checking the servo saver. I will take some picks and a possible video when I get home from work. Thanks for getting back with some help💪
Found the issue,the screw has come all the way through on the servo saver making it sloppy. Is replacing it with stock the best way or are there any better options out there
Would you replace with stock or purchase an upgrade after market one on
Oh yeah forgot to mention I'm from the UK,lol. I can get the complete servo saver assembly for about £14 compared to hot racing aluminium one for £55 so I think stock is the way to go as I can get three sets for the price of one aluminium one. Thanks again for the help and advice
replace it with stock and if it happens again Id replace it with an aftermarket aluminum one.
Well after swapping out the bellcrank assembly and adjusting the end points it seems the toe link is still touching the suspension arm on full turn that you can see in the pic, is this normal or am I worrying over nothing. The last pic shows it when the wheels are straight and there is plenty of space, I'm starting to think I'm worrying about nothing(hopefully)🤣
