Greywolf74
I'M TO BLAME!
Lifetime Supporter!
RC Showcase: 8
Should I go ahead and put this Boca front bearing in my Picco that I have or just wait until the stock bearing goes bad? Theres nothing wrong with the stock bearing and the engine is fairly new.
Also does the Picco P3 .28 use standard or turbo plugs? My understanding is that it uses standard by default but you can buy a turbo head for it. That sound about right?
What size and how many shims should I buy using on this engine running 30% nitro? It came with four 1mm shims under it (used) but I'm pretty sure it only needs 2 or 3 tops
