Witch differential is better for drift ?
Sweetlou0069
Hi so I was woundering witch would be better for drifting ? The one looking like a shaft is almost solid theres bearing to make the wheels move in opposite direction but it barley moves , the other one is the opposite if u lift 1 wheel it's that wheel that'll spin n not the other n you can make only 1 wheel turn.
What kind of car is it for? Some guys say use a locked, or almost locked diff in the rear, and a one way in the front, if its 4WD, but, if its 2WD, a locked diff can cause it to spin out a lot more. I learned that by locking the diff on a 2WD SCT, just to see what would happen, and, it did awesome donuts every time you tried to turn. It also depends on your driving style as well.
It's a hpi sprint 2 flux 4x4
