Coach Z
So I need something to keep me busy over the winter and I've been thinking about getting into electrics for a while so I've decided on an Axial crawler to start with. Seems like a great setup out of the box with lots of support and many people have done it before me so I can look to other builds for ideas. Because this is my first venture into electric I'm looking for suggestions as to what parts to use for the build.
So far my plan is:
Axial ax10 kit
Radio - Spektrum DX3R Bit overkill but going to use it for my LST2 as well as an 8ight that I'm building to hopefully race
Servo - Hitec 985 @ 172oz. or a JR 9000T @ 320oz. More is always better right?
Motor and esc -Novak seems like the go to for this stuff so I'm debating between the rooster and the goat brushless. Is it worth an extra $150 to go brushless if I'm not competing. That said I usually end up taking things to the extreme anyway!
Battery - Max amps 7.4v 1720mah - Is this going to give me enough run time or should I go bigger. I'd like to keep it as light as possible??
Charger - Superbrain 989 Maybe a bit much but should do anything I ever need
Are the Axial option parts a big help? I'm thinking the battery tray over the front axle is a good idea but what about the rest of it?
Thanks guys and as always
So far my plan is:
Axial ax10 kit
