Look don't get wrong, this site encourages debating and friendly back and forth conversation, but you take it somewhat of a personal unsolicited attack, calm down. I myself don't care what you own or have, no need to try to prove your self.
Isn't it fun to ask questions then get upset when you get the answer. My wife does the same thing.
Here is a good tire guide from RC author Matt Higgins.
> Soft compounds offer the most traction, but wear faster
> For bashing, run the hardest compounds available as they’ll last longer
> Cold weather racing requires soft compounds
> You don’t have run the same tires front and rear; sometimes it’s helpful to run tires with less grip up front on a 2WD short course truck
Loose, Loamy Dirt. If the dirt is loose, a taller tread is needed to dig into the dirt. A tire like Pro-Line’s Caliber work well on this type of soft dirt. If the dirt is sticky, a tire with a lot of space between the lugs may be needed so that the dirt doesn’t pack into the tread but instead gets flung out. Tires with multi-layer treads like the Caliber also work well when I track first brings in new dirt that hasn’t fully compacted yet.
Hard-packed Surface with Loose Dirt on top. a tire with too tall of a tread with feel like it’s floating around, so a medium-sized tread works best. Good examples are Pro-Line’s Bow-Fighter and Blockade tires. If the dusty top layer is noticeable, try a tire like the Bow-Fighter. If the there is dust or a loose top layer in some spots or if the track conditions change but are mostly dry (just not muddy), try a tire similar to the Blockade.
Hard-packed Dirt with Some Dust on Top. If the track your running on is fairly hard packed, but doesn’t get swept clean of loose dirt and doesn’t have a noticeably “clean” groove around the whole track, you’ll need a tread with a little bit of height to get down to the surface. Pro-Line’s Sniper is similar to its Hole Shot, but designed to have that slightly taller tread.
Outdoor Hard-packed and Blue-groove Conditions. If the track surface is hard-packed, a tire with numerous small lugs will be able to work best. Pro-Line’s Hole Shot works well when there isn’t loose dirt to have to dig into. The numerous small lugs provide a lot of surface area and a lot of grip on the smoother surfaces.
Indoor Hard-packed and Clay. While tires that often work on hard-packed outdoor tracks may work indoors, usually tires with low bar shaped treads mixed with equally low but-traditionally-shaped lugs will provide a lot of contact with the track and good forward and side bite. An example would be Pro-Line’s Suburbs.
