Why does it stall
traxxas t-maxx
portland
Okay so we drove the evader today over of coarse broke it, my question is though when we would give it gas it would sometimes act like it was calling for to much gas and when you gave it gas it would kill itself. So we leaned it up a bit and that didn't help so we richend it back up just for the hell of it and it fired rite up. So when we got that problem worked out we got another one; every time you let of the gas it would stall but when you first started it, it would idle great. So what could that problem be and, how would we fix it.
First make sure the carb is opening and closing properly then start from stock settings. How is the pinch?
make sure the spring on the throttle linkage is tight enough so the carb opens and closes acurately
Ya everything is set up perfectly I think what I mean by that is linkage. When you hit the brakes it doesn't close any more than it does when its just sitting there. I don't know I need help. I will get it out probably next week we need an idler gear for it the slipper was to tight and the tires are so meaty they just shreded the gear.
I would start from stock settings set your HSN first once that is set then you set your lsn.
Sounds like your lsn is out of whack to me.
