alien13
Still not sure how I shredded the 2-spd gear, but I'm still digging teeth out. I pulled the diff apart, there's a touch of play in the outdrives, but the planetaries look good. They are greased, should I clean them out and use oil, if so, what should I use. (Two-wheel drive)
What's the best cleaner for removing all the grease from the diff, and the gearbox?
What can I use to clean the bearings, without wrecking them?
I'm switching to hardened steel gears from Robinson Racing to replace the plastic 2-spd gears, leaving the spur gear and diff plastic. So what grease should I use? My lhs gave me Hob-E-Lube Moly Grease P/N HL656 to put in the gearbox, said that is what he ran in his stealth gearboxes. Will that work?
Other than that, nothing is wrong. All of the bearings are good, there's no play anywhere other than the outdrives, but as I said, the diff looks great.
