TK5310
My picco .28 turbo powered revo has been chewing up the driveline piece by piece, I've now got to the point that every single component in the driveline is steel (Hardened 1/8 buggy bell with 4 shoe progressive alloy clutch, RR steel slipper conversion, RR full metal gear set, TRX steel driveshafts, steel CV 1/2 shafts, billet alloy diff cups).
I thought I had finally managed to build a bulletproof driveline - then I snapped the primary shaft in the trans.
Maybe my fault - running big joe tyres with a tight slipper on concrete.
I've got a new trx primary shaft on the way, I'll loosen up the slipper & switch to my badlands tyres for higher traction surfaces - that should reduce the load on the shaft.
But methinks it's just a matter of time before I break another one & they are not the cheapest 'consumable' item.
So, anyone know where I can buy or get made a tool steel primary shaft that'll cop bulk abuse?
