I have a brand new Exceed Forza buggy, the other day I decided to take it out of the box and start it up. When I pulled the air filter off and worked the throttle, the carb was only opening less than half way. I adjusted that, and also the brakes where slightly on from stop, so I had to adjust that also. The receiver had no wire to run through for the radio pick up. It was hanging by one little line and broke. The body had no holes drilled for the radio wire and the body was not notched to clear the front turning arms and the body sit crooked on the chassis, it's warped. Anyway I started up the engine and let it idle, it was running OK then after about 40 seconds latter I started smelling something. I looked down at the front of the engine and the clutch "out side coupling" was starting to turn blue and smoking. So I quickly pulled the air filter and placed my thumb over the carburetor and killed the engine. I packed it all back up, called the store and got a RMA number and sent it back to the supplier for a replacement. Out of all my years with RC nitro cars and planes, helicopters, I have never had a lemon till I got this buggy.
