Wheels turn while idealing
brad55102
Grand Rapids, MI
I'm breaking in my first nitro, just running it on the bench and while in neutral the wheels turn and i can't stop them. I tried adjusting everything but short of applying the brake i can't stop the wheels from turning. Is this normal? What should i do?
did you lower the idle a little? it could also be the throttle trim on the radio. unless you've tried them, i dont know what to say
Check you clutch too. you may have a ruined spring or seized bearings.
During break-in, engines run pretty erratically. It may smooth out the more fuel you run through it and accept your needle adjustments better.
Just something to keep in mind.
