What motor to choose ?
TINY_MAXX
Canada
I have a traxxas nitro 4-tec and it has the original .15 motor in it and it has needed a rebuild for a while so just took out the shim and raised the compression as i knew if the motor went i could replace it, and the time has come for a new motor. What sizes can i sqeeze into this beast, I've been out of the hobby for a while so I'm not up to date with what new motors have come out and which ones are better performers, so any help would be appreciated.
thanks in advance.
-Ryan
Does anyone know if the chassis layout on the newer nitro 4-tec differs from the original with the oldschool .15 ? Also will the new 3.3trx need any other upgrades to utilize this motor? (new throtle linkage etc.) I'm looking for a motor that can easily just be dropped into the car.
I'm not a fan of the car,but I believe it should bolt right in,I believe the newer model of that car comes with the 3.3 so it shouldnt be to hard.You might need a new header and pipe? But it would be worth it for the swap I believe.
You'll need a new linkage too since the pro .15 is a rotary barrel carb. The newer 2.5 and 3.3 both use slide carbs.
