what fuel do you think is better???? (poll)
Maxxcrazy88
So what fuel do you like better O'donnel or trinity Monster HP (both 20%)??
just want to know
I have used one of the two you mentioned and Trinity works as advertised.
I have used several of the major manufacturers fuels available.
The only issues I have had was with the Fantom Fuel, It foamed like dish-soap.
For racing I like 30% BT.
I just started using the triniity Monster Horsepower, and the stuff is really good.
Can i vote for neither ? but i suppose if i must go for one trinity monster fuel was ok but eninges ran hotter
I wonder how many people like Blue Thunder. Some people really like it, and others wouldn't give it to the neighbors cat to drink, let alone put it in their RC. There doesn't seem to be a lot of middle ground. My lhs always has BT, but when they get Trinity, it lasts only a day or two.
i prefer blue thunder right now the engines just seem to run better and cooler on a temp gun i recently switched from trinity to blue thunder when lhs was out and wont switch back
I have used blue thunder with no problems at all, I also tried Traxxas top fuel, it was crap imo, I won't use it again. I now use Trinity monster and like it quite well.
o'donnel I seen a engine at the lhs that trinity had gummed up I would never use trinity after seeing what it did to that engine
How long was the engine left with fuel in it and not run? There are alot of things to take into consideration when you see something like that. When I am done running, I make sure I run my fuel out and that the tank is empty. I always use after run oil if I know it will be sitting more than a day or two tops. Propper engine care will prevent that no matter which fuel you use.
Odonnel bar none. I used trinity, but after trying odonnel, I was converted. To me there was a big difference in perfomance and lube.
The one thing I really hate about odonnel is it stains everything yellow. I think its the castor because it my pressure line has turned from blue to yellow. Same with my fuel tank, and whatever comes out of the pipe. Other than that I think I'm sticking with this.
I hear blue thunder is good as well as redline. My friend runs redline because he cannot find odonnel. A very reputable LHS out here has been getting a lot of requests for Odonnel and are now going to carry it.
