Went Racing (Prospec help)
PiErow
I had tons of fun today. Nitro-Basher and I hit up the track to practice. We went to Carolina Rc Center. Really nice track if you ask me. Anyways i had tons of things go wrong with my Prospec MSR Truggy. Just little things like screws coming out and stuff. My car was slow compared to those damn little revo's so i am going to give it a nice tune then a good bath... On to my question
Those little revos turn on a dime. I need to reduce my turning radius on my MBX Prospec, how do i go about this?
Diff weights 10/30/3, keep in mind its a truggy so i use heavier fluids...
REVOs are hard to beat when they are set up right.....there's one at mills pond that fucks w/ buggies and usually wins....course its driven by Scott Beiswinger...
Yeah, pesky lil buggers. On the right track they can kill truggys, and buggies.What shock/ spring combo are you running? I have my Storm shocks w/45 all around, Ofna white springs. I may want to look at a stiffer spring.
Your diffs don't necessarily need to be that thick. In my LSP I'm running 3,7,1 and so far I love it! I'll find you what the pro's are running for total setup and that should give you a good idea where to start.
From Mr Msr himself Chad Bradley.
standard track setting
Front:
Oil............400wt
piston.........1.5
spring.........grey
shock pos......one hole in on tower; outside on arm
ride hight.....bones level
shock length...loosen shock end 2-3turns
ackerman.......middle; raise rack 1.5mm
front width....277
front lower arm..2mm washer in front of arm
camber.........-2
toe out........1-2 degree
castor.........middle
upper arm pos..middle insert on tower, lower insert on back plus 1.5mm
washer
diff...........5000 no small orings
center
diff...........7000 no small orings
gearing........stock
clutch.........aluminum shoe 1.0 spring
brake disc.....ttr
Rear
oil............350
piston.........1.5
spring.........grey
shock pos......one in on tower; outside on arm
shock length...loosen shock end 2 to 3 turns
hub............aluminum
hub pos........middle; use lower hinge hole
camber.........-3 degree
camber pos.....upper inside on hub; inside middle on tower
toe in.........3 standard
antisquat......middle insert (2 degree)
diff oil.......2000 no small orings
bumpy track setting (usually at hemet and pro-line
Front:
piston.........1.5
spring.........blue
ackerman.......foward hole; raise rack 1.5mm
front width....277
camber.........-2
washer
center
brake disc.....ttr
Rear
oil............350
piston.........1.45
spring.........blue
shock pos......one in on tower; inside on arm
camber pos.....upper inside on hub; inside lower on tower
only a few changes from standard settings, but they make a big
difference.
Is 400wt, 40 or what? Thats heavy.
How do i adjust ackerman?
Whats bones level?
I will set it up today and see how it runs.
I think he is using mugen fluids, I'll get you something for that too Ackerman is the slider that controls the steering (I'm pretty sure on that one) Bones level are drive shafts level. Post the conversion thingy in a few.
I have mugen fluids so it doesn't matter. My prospec kit came with this set up sheet thing that showed you what everything was, and a place to write down what your using. I am going to spend my afternoon setting up my starter box (grounded it out the first start yesterday),cleaning, and then adjusting. I also broke an upper hinge pin so i have to order that.
Thanks for the help VB.
