- Thread starter
- #21
minmax89- maybe it is not your bearing that is leaking. you might need a new crankshaft. possibly theres a spot on the crankshaft that is not sealing with the bearing?
Oh my god lads! Seems darkslayor24 may be right!
I finally got to do a test tonight.
One engine with backplate, carb neck/pin sealed - check!
Spare piece of fuel line on carb nipple - check!
spray bottle with soapy water - check!
Wife holding camera while I thumb over the carb filter neck and exhaust header - check!
So I sprayed , then blew. The result:
Although the video is a little out of focus it clearly shows the bubbles. What it doesn't show too well (but is crystal clear in the flesh) is that the leak is actually between the inner face of the bearing and the crankshaft.
This test only confirmed what I knew from blowing it when it was dry. I could feel cold air on my hand.
I bought this engine last week from Absolute Hobbyz on Ebay. I contacted them when I thought it was the bearing and their reply was:
"...if the bearing is leaking oil/fuel.. the low speed
needle is rich. it will also leak some during break
in because of running the engine is rich..."
So now I'm about to send them evidence of the current situation.
Can anyone offer any advice as to what to do here??
Adam
