Waking up Receiver packs
NCNitro
Fist of Goodness
In Memoriam
Central Florida
Since I live in the land of no rc fun, no rc tracks, many of my R/Cs have been sitting for a while. I prepped the mills fine but neglected the receiver packs. I decided to put a charge on all my receiver packs. They all seem to be taking a charge, but not a full charge. Whats the best way to go about getting my nimh receiver packs back or as close to full strength as possible? I am using an ICE charger if that makes a difference.
I did the same thing on both of my 5B receiver packs. No matter what I try, I can't get them to accept a full charge anywhere close to their mah ratings.
I gave up and will be building some new packs and be more diligent.
Damn, that's not what I wanted to hear, lol.
You might try cycling them at a low amp rate, and don't charge them over 0.1 amps per 100 mah...
I tried that, at that exact amp rate, not coming close, with the exception of the one in my sons T-Maxx, that one seems to be charging at full strength.
You might try a regular old trickle charge then and see what that dose....like 0.2 amps over night...I know small cells like the AA type don't like to be fast charged...for the most part...
I've been there, done that. The best thing you can do is charge them to as full as they can take, and then discharge them. I have a discharger that I made with an automotive relay and an 1157 tail lamp bulb.. I can give you the diagram, if you'd like.
Actually the ICE charger has a built in dis-charger, cycler. But thanks for the offer.
