- kentucky
- Racing
- Crawling
- Scale Builder
I've never dine this, i only halfway know what I'm doing. this should be a learning experience.
i bought my son a banggood rc truck
i tookit for a few laps in the street then decided (like a dumb) hey lets put the 3 s battery in it!, well its only rated for 2s so i burnt it up.
i read a bit and watched a bit and decided i must have burnt up the esc. allegedly it wouldnt have burnt out the motor itself as it wasn't enough juice for that.
the wheels still turn it just wont accelerate or reverse.
so i go to the website and get the most info I'm able to about the truck
i ordered an amazon esc motor combo is my first attempt I'm not trying to learn on expensive things
Max current: 50A
Max watts: 600W
Max voltage: <12V
IO: 1.8A
Rotor poles: 4
Resistance: 0.0285
Diameter: 28mm
Length: 38mm
Shaft length: 15mm
Shaft diameter: 3.175mm
Weight: 90g
Sensored: No
Features of ESC:
Highest quality components to ensure high efficiency operation
Excellent start-up, acceleration and linearity features
Plenty of programmable items, suitable for various of chassis's, tires and racing tracks
Multiple protection features: Low voltage cut-off protection / Over-heat protection / Throttle signal loss protection
Internal timing can be changed easily to make the ESC suitable for various of motors
Specifications of ESC:
Constant current: 35A
Burst current: 120A (10S)
Power supply: 2-3S LiPo battery / 4-6S NiMh battery
BEC: linear mode switch 5V 2A
i didnt read untill much later that the reciever and esc are a combo factory. i didnt order a reciever oof.
on the 16th I'm expecting a delivery of a lot of different items and i swapped out a few and am ordering a
the motors are about the same size
i keep running into little issues but i roll with em
i got to looking closer and i think the drive shaft of the stock motor is larger than the new motor so now we get to learn about pinion gears. i want to start but am having to wait on the mail to go any further,
any help and advice will be SO appreciated as I'm a complete noob at this, i dont know what I'm doing and I'm learning as i go.
end goal iws to learn enough to build my own custom rc maybe i dunno i just know 1k for an rc car is out of my league but if i build it maybe its cheaper. hell my luck ittl be waaaaay more expensive. but it would be mine so i would love it and snuggle it in mud and dirt.
Basic information | Brand:JJRC Models:Q130 B brushless Model:1/14 Speed:70km/h | Power system | 35A ESC and receiver are 2 in 1 Motor:2840 4000kv brushless Servo:3 Line LED headlights, LED roof lights, LED tail lights |
Transmitter | Frequency:2.4 GHZ Battery: 3XAA battery(not included) | Battery: | 7.4V 1500mAH 15C Li battert (T plug) |
others | Charge time:180-210min Using time:15-18 min Control distance:120m Function:forward,backward,left,right Proportional controlroportional control It adopts plant differential. | Dimension | Size:34.5*20.5*14.8 CM Transmitter size:13*7.5*21 CM Wheelbase:18.8 cm Axle base:18.5cm Tire:8.5cm Package size:57.5*36.5*53.5 CM Car weight:1160g Package weight::1900g |
GoolRC 2838 4500KV 4P Sensorless Brushless Motor & 35A Brushless ESC Electronic Speed Controller for 1/14 1/16 1/18 RC Car
KV(RPM/Volt): 4500KVMax current: 50A
Max watts: 600W
Max voltage: <12V
IO: 1.8A
Rotor poles: 4
Resistance: 0.0285
Diameter: 28mm
Length: 38mm
Shaft length: 15mm
Weight: 90g
Sensored: No
Features of ESC:
DUMBORC-X6 2.4Ghz 6 Channel RC Transmitter with Receiver Low Power Alarm and Out of Control Protection RC Radio Controller for Remote Car/Boat/Tank Mixed Mode Remote Controller (Without GYRO)…
I've taken it apartthe motors are about the same size
