trx4 with treal wheels
traxxasmike410
pasadena md
  2. Crawling
i have some sweet treal wheels with proline hyrax predator compound. i really abuse this rig. any suggests on inserts. it manly is a trail truck. i ocasionally take it to key city hobbies and run their course. what's your thoughts
For what it's worth, I think the tires matter more than the wheels. You can trim the foam if needed.
I'm running Injora wheels (slightly wider (+3mm) than the Treal) and using the Proline Dual Stage foams. The worked well with the Hyrax but a bit loose with Jconcepts Ruptures.
Injora Wheels might be a touch wider. The inserts are 24mm wide as well.
