trx power charger
tsiap
hi there, the charger says maximum charge time "90 min" so if i have a 3000mah to charge i have to cycle 3 times, approx 200-240 min to fully charge
what it means exactly?
thanks
I'm guessing you are talking about the black box charger that comes with the Traxxas rigs? If so then yes that is about right. The charger is designed to charge an 1100mAh (I think) battery in 90 minutes, so for a 3000 you would have to do it 3 times. Your best bet is to get a separate charger for your other battery packs and use the stock charger for the receiver pack on the rig.
yeah get a hump pack adaptor for your revo and charge it with a peak charger. i do that with my stock 1100 mah battery, and ill never use that stocker again
with a nice peak charger you should get a full charge out of a 3000 mAh battery at 3 amps in about 15 min or so
