psunitro said:Yes it is!
Looking back at my post, I screwed up my calcs as I was summing the ratio’s instead of multiplying them,Toolman said:The stock Lightning has 43/13 ring & pinion ratio & a 46/13 for the spur & clutch bell.
The Stadium has 43/10 & 50/13 ratio’s this adds up to 8.1461:1 overall.
I’ve got a 48T spur for my Kyosho, so with a std 13T clutch bell I would be getting about 7:1 overall. If I switch to a Hot bodies ring & pinion I would get around 8:1 which should be close enough.
vbgagnon said:not the spur the ring and pinion gears that go in the front and rear diffs, If you don't mind ordering from the states here are a few links that have them......
a-main hobbies 2 links for 2 parts
http://www.amainhobbies.com/product_info.php?cPath=25_104&products_id=2898
Mondo said:The Ofna Blazer comes with a 12T clutchbell. I upgraded mine to 13T as the HN Force .25 motor has plenty of grunt.
Look on EBay.com (not Ebay.co.uk) and you will find Blazer parts
