CertifiedMike
RCTalk VIP
RC Showcase: 1
- Southern Maine
- Racing
Take the glow plug out and turn the car over to see if you've flooded the cylinder with fuel.
Gases compress, fuel does not. Too much fuel in the cylinder and the piston can't move. Damage can happen if you try to force it.
Since you have smoke... stop.
Make sure your carb is set correctly to factory settings before you try to start again.
Also double check the battery. Dying ez start battery will ALMOST turn the engine over but no full rotate or very slowly.
The low voltage will not heat the glow plug either, it won't start.
