So, first of all, sorry that I didn't write for a longer time, I repaired the car and drove a little bit. I just hadn't had the time to post it as I have written a lot of exams lately, so I had other things to worry about.
But I will add everything in here that I changed / had to repair, so this is still 100% complete.
First thing you need to know that shortly after I repaired the Servo Saver (the broken one from the post above) my Spur Gear stripped again and the Ball Bearing of the Slipper broke.
New Parts:
- KB124 Kimbrough Servo Saver
- TRX4686 Spur Gear 86T
- TRX3790 Fixed Gear Adapter
- 1x Ball Bearing 5x11x4 2RS sealed (just one of ebay)
- MH550TE16 Hot Racing Heat Sink
- Servo to BEC Cable (the Fan Cable wasn't long enough)
- TRX3725X Battery Expansion Kit
- RPM 80332 Body Savers
So, the truck has about 25 packs through, what can I say about the new parts (although some of them are only a pack old):
The Servo Saver is nice. It does its job, hasn't broken and seems to be pretty sturdy.
The Spur Gear and Ball Bearing work, and the Fixed Gear Adapter sits in there nicely (I just wanted to make sure that the spur can't break because of the motor moving. I ruined two spurs now, I don't know why, so I want to exclude this as potential reason). By the way,if you are interested in what gearings the adapters do support, I have a photo of the gearing charts below).
The Heatsink (which as you can see in the pictures below is not used completely, only some parts of it) works really great, the motor was staying pretty cool the last run. The cable extension, well, extends the cable as needed.
The expansion kit works...but I have a feeling the holes on mine are drilled on the wrong heights (after installing it normally I couldn't put in the body clips on the lowest position even without a battery, the plastic battery holder was covering a part of the holes). With some washers installed I could use my small batteries again, but now there was some place left to wobble for my bigger Lipos. So, I glued some foam to the plastic battery holder on one side, now I can just simply turn it around with my bigger packs and they also sit there without moving.
The Body Savers were intended for the Holes on the back of the truck, but unfortanetly I couldn't put them on properly because of the structure of the truck bead. So now I just glued together both parts of them and put them between the body and the clips, a bit tedious but works alright.
So, how does the truck drive? Well, because of the longer gearing and the higher center of gravity because of the Battery Expansion Kit it now wheelies even a bit more, and now it gets a little bit to much to be honest. It is even harder to acclerate without a wheelie. But I have a feeling the balooning tires might be part of that problem, and I will look into this a bit later.
To finish it of, here are some pics:
The new Servo Saver
The Heatsink
The Battery Extension Kit (smaller Lipo)
The Battery Extension Kit (bigger Lipo)
Just to add it, how I plug my Lipo in normally so the Cable doesn't hang down on the side
The Body Safers
And to finish it of, the Gearing Chart for the Fixed Gear Adapters
