Titanium help
newnitrofan
Irving, TX
Sup guys well I just purchased a pretty solid sheet of Titanium it is aircraft grade and is .160 thick or 4.064 mm thick. Well I plan to make some TVP's and possibly some other stuff for my savage. I need to figure out what I need to purchase to cut it and polish it. I have a drill press for putting all of the necessary holes in it and a bench grinder for de burring it and a dremel for most of the detail work but I am wondering what the hell I'ma cut it with. Anyone have any good ideas. It is aircraft grade 6AL4V Titanium. I'm pumped to do this. I am sure it would have been easier to just purchase some hardcore crap but what is the fun in that?
Dang man, I don't know what you'd use to cut titanium. I know if you buy a titanium ring, they tell you that it can't be resized because it's too hard of a material.... and if you ever get in a car crash or something and they need to get the ring off but can't, they have to cut your finger off because they've got nothing that can cut a titainium ring. Sounds crazy, but 2 different jewelery stores told me the same thing.
There's gotta be a conventional way though. I'd start out trying a grinding wheel on a Dremel or somthing like that.
Hmmm Gil I was thinking of using the dremel but for that size of titanium I was thinking that a dremel would just take forever. I am thinking of getting an 4inch grinder with a good solid cut off wheel to cut it that way I could use some serious cut off wheels to get after it. I am also wondering what to polish it with.
After reading stretchM's first link, it looks like you have your work cut out for you.
I use a reciprocating (jig) saw to cut cold steel for making parts, but I wouldn't know where to begin with titanium. It looks like in the second article that a band saw is used, so you might want to start with something like a reciprocating saw at first just to see if it will cut.
Yeah from what I have read it will be best to use something that cuts slow but fine. Apparently titanium has a tendancy to spark and cause fires so I will have to be plenty careful. Thx.
Hmmm stretchM's second link says if you have some sort of coolant or oil based water around than most any sort of cutting wheel on a slow RPM should do it. I think this is going to be easier than it honestly sounds.
Just wanted to update this thread for all of the naysayers saying it can't be done. Ok first off I'm gonna straight up admit it's going to be a lot more work than I originally thought. However When I'm done I'm gonna have me one bad ass ride for sure. Don't know how original I will be with designs but I'll figure something out. Honestly It would probably be easiest to just throw this thing in a CNC Mill machine but I just don't have it in me to do so. Newayz I found that with my old ass hacksaw with a blade that is probably about 8 yrs old it will cut it slowly but it will get cut. Here's some pics. I'll update with more pics when I manage to get s'more cut.
www.nitrofan.net/dscf1060.jpg
www.nitrofan.net/dscf1061.jpg
www.nitrofan.net/dscf1062.jpg
www.nitrofan.net/dscf1063.jpg
www.nitrofan.net/dscf1064.jpg
www.nitrofan.net/dscf1065.jpg
www.nitrofan.net/dscf1066.jpg
Edit: the pics were to big for forum rules so just click the links.
