Throttle controle not responding
Daniel C
RCTalk Champion
Oregon
  3. Crawling
  4. Scale Builder
The rc truck I have been working on busted a gear in the gear box so it was down for acouple of weeks and when I got it all fixed and powered up the transmitter everything worked but the trigger. I could drive the truck by turning the throttle controle uo or down but could not use the trigger. I pulled the transmitter apart but did not see anything out of the ordinary. Does anyone know what might of happened or how I can fix it?
Re-bind and then re-calibrate. That's usually what happens.
Ok thanks after I posted that I thought of that and looked up how to on u-tube because I have forgot how. Thanks once again your full of wisdom and have a answer. What would I do with out you all. I'll post if it works or not.
