islandlife
- Racing
- Crawling
I'm running the same esc in mine, and i also drilled new holes in the plate for mounting
I will be using 2S packs that have 5mm "tubes". I was trying to make sure I had enough battery wire length to reach back of battery tray. I'm not sure if my orientation of the ESC is the best way, but for now, it seems to be working out.I'm running the same esc in mine, and i also drilled new holes in the plate for mounting
The gold washers are a nice touch, who makes those?
Looks like that should help. Whatever you do, don't put an o-ring on it or the Traxxas lawyers will sue the pants off yaShoving It All In There
Receiver mounted, and my attempt at dirt entrance mitigation...
Well, Horizon Hobby may want to jump in on this one, 'cause my backup plan is this Axial knockoff:Looks like that should help. Whatever you do, don't put an o-ring on it or the Traxxas lawyers will sue the pants off ya![]()
Oh, a nice silicone seal there. That should do nicely!Well, Horizon Hobby may want to jump in on this one, 'cause my backup plan is this Axial knockoff:
As per the manual, the stock droop settings are 98mm/108mm. Well, built as per manual, I was on able to get the shocks 96.82mm (front) and 107.62mm (rear) eye to eye measurements... close enoughWhat are the shock lengths eye to eye, and OD of the shock body?
Dang, those wouldn’t work for me then, I was looking at options to replace the shocks on my xterminator nitro buggy. But they seem like the diameter is pretty close, and the rears would work on the front. Well now that I measure these shocks, those probably could work…….. Thanks!Shock Length
As per the manual, the stock droop settings are 98mm/108mm. Well, built as per manual, I was on able to get the shocks 96.82mm (front) and 107.62mm (rear) eye to eye measurements... close enough. Shock bodies are 16.25mm at the threads.
Do you not have your endpoints on your servo set?Steering Stop Screws
Having lots of steering is always nice, but that last little bit of steering throw, on the SCT410 2.0, has very little leverage on the inside tire while going into a turn. This allows inside wheel/tire rubbing on my 2.0's arm. The 2.0 manual does not suggest, nor does the kit come with, any steering stops (screws) to physically control that last little bit of movement of the inside spindle/steering block. There is a molding mark on the spindle and I though it would be a great place to add a M3x6mm button head screw.
A soldering job doesn't get any easy than what is needed for these connectors.Been looking into those types of packs. Once my old SMC 7200s give up.
But first I need to learn how to solder bullet plugs better.
