Build Thread Teardown and rebuild of a Duratrax Axis
Enuahs
New England
Had some of this on a RCNitroTalk forum but thought it would be better to put the rest of the work here.
So background, a friend found this car and had not idea what it was or how to get it running. I have a couple of Nitro cars that I have fun with as often as I can so I said I would happily rebuild it for him.
Better to tear apart his car than mine right ;-)
Started the strip down.
Clean up and assessment
So the other night I started the rebuild of the differentials!!!!!
Not a bit of oil in any of them..
Say what you want about the quality of the Duratrax (I have read many of them) the gears were in really good shape for not having any oil and lots of dirt.
Some diffs use oil, some use grease. Did your diffs have anything besides dirt in them?
Cleaned and oiled up. I added some grease around the edge to hopefully act as a seal.
Then my first replacement part showed up :) the reset should be delivered tomorrow. Thank you ebay this would been a very different project without it.
Until the other parts show this is pretty much as far as I can go tonight
Latest photos of my progress.
Getting close to a roller.
The carburetor was a mess I forgot to get pictures before I cleaned it up. All the components looks to be in good shape just really dirty.
This picture does not do it justice but the engine is a black sticky mess also. :(
Thanks for the complement! Whats better than rebuilding R/C and then running them right!? Build run fix brake remake!
Well She is now a roller
I still really need to clean up or replace the rims but right now I just want to see her move :)
Engine all back together and sealed up.
Pull start added
Now I get to wait for the silicon to dry over night. I guess I could install the engine while i wait.
I still need to find some place to get a seal for the gas cap. Any thoughts?
Well she started up today. I still need to pickup some stuff but the engine started and ran.
Well there she is all back together!!!!!
I just need to find a body now and she should be good to go. I was planing on bringing it down to my LHS to see what he has that will fit since finding an original stock one on the net has been a bust. I was even searching sites in Italy with no luck.
I have not had a chance to really run it yet, I hope tonight. It did start right up though, I must admit i was a little surprised since this was the first time i striped down a nitro engine and rebuilt it :)
Wow that's a helluva transformation. Are you reluctant to give it back to your buddy?:p Have you got any more run time on it?
Finding a body to fit an 1/8 buggy shouldn't be too difficult. I prefer the newer style bodies with the higher roof line like the Proline Bulldog or the HPI Trophy 3.5. for example. There's less chance of your air filter being mashing against your throttle servo with a taller body. You could use a low profile air filter such as this if you do encounter interference issues.
http://www.ebay.com/itm/HoBao-1-8-H...Control_Parts_Accessories&hash=item5b0718cdae
Its a good idea to invest in a body reamer, lexan scissors and an Xacto knife if you don't have them already because you will be doing some trimming, guaranteed
I would agree on the body thing, if it is the right scale size and you compare the mount style / wheel wells / engine hole etc you should be able to match one up. Especially if you get something un-cut and un-painted then you could set up your mount holes etc yourself!
It does look awesome! Looks like it will rip!
