Team associated help with the ntc3 braking only in the front?
street silence
RCTalk Champion
It’s this normal or does it need to brake from both rear & front? Thanks guys
The brake is applied to the drive shaft which will affect front and rear. If rear isnt braking then you need to check if the rear is accelerating properly. If not then something in your rear diff is stripped would be my guess
The AWD works but when I brake it only sends it to the front wheels
Just out of curiousity what makes you think only the front wheels are breaking? I ask because I dont know how you could have AWD and only front brakes. As Baker said the brake is applied to the front and the back at the same time.
When I’m on the brakes the rear spin freely while the front don’t
nothing was wrong so the brakes do work it just spins freely when it’s on a stand with the wheels on the air but when it’s on the ground it brakes perfectly fine
when you say it spins freely do you mean while its on the stand and you have the electronics turned on and the brakes applied or just when its sitting there period?
If you do mean when its on the stand and the brakes are applied I'm assuming you mean the rear spins but the front doesn't?
Sorry, trying to wrap my head around this problem
Yea when is on the stand the rear spins & front doesn’t but when it’s on the ground both front & rear work
What you said, when i had it on the stand with the brakes applied the rears would spin freely
That is a solid drive shaft car ,single brake should work both front & rear diffs together ,unless you
are the second owner an the first owner put a 0-way diff in the rear!
A 0-way diff will catch one way ,but will free spin the other way in which may cancel out the brake!
O-ways are normally used on race tracks ,an are usually used in the front diff for cornering!
Dang Sensei...Import more previously unknown knowledge my way! @cbaker65
That is exactly what I was thinking, it may be setup for drifting or something.
I am not a racer ,however ,I did learn the hard way when I used a o-way diff in the front
on a car that is for speed runs ,didnt go too well when I was braking at high speeds!..😢
This is why I was concerned the last time I drove it (like last week) it felt like it was braking poorly but it might just be me over thinking. I been toning it righ now for the next run. It only sounds in the air though, when I set the car on a wheeler the brake start working that’s me on the the brakes ont he remote controller
Bro my first 1/10 scale lost signal at like 40mph in to a curb
6
easy rider
I
33
Louis p
Louis p
Armysolo
johnnydmd
johnnydmd
