I’m in the same boat for looking at getting into electric no prep. Here’s what I’ve found
Drag Slash is good but limited tuning wise unless you add aftermarket parts.
DR10 is a great performer similar to the drag slash but with better tuning options out of the box
Losi 22S drag car has been discontinued but still looks to have good parts availability. I personally think this is the best looking option
DR10M will be the fastest of these options as it is a mid motor and has a better weight bias. Not to mention other suspension and chassis options that have been upgraded over the DR10
All these platforms have extensive aftermarket options to the point where they will hardly resemble their out of the box counterpart.
If I just wanted to have fun and budget wasn’t a factor I’d get the drag slash. Parts for it will be at every LHS and it will likely be around for a while.
If budget was a factor I’d look at a used 22s or used dr10 RTR
Currently the boat I’m in is that budget is a factor as I’m not sure how far into this I want to go. I’m leaning towards the DR10 as it seems to be the best entry level option from a price and tuning standpoint. It has some pretty intense aftermarket options also.
If budget wasn’t a factor I’d buy the DR10M kit because it will perform better. But currently is listed at slightly over half the price of the DR10 on Amain
If budget REALLY REALLY wasn’t a factor I’d be looking at a DragRace Concepts, Exotec, or Custom Works kit
Racing locally id find what classes are ran by your local club. If they don’t have a class for what you buy then you’ll have to modify. Best bet is a box stock class that you could race an RTR in. Here in STL the nprc guys mostly run Outlaw dry tire because of low turnouts and being unable to form full classes
