You can convert, but there are more things different than you realize. The E uses a different tranny, manual shifting, and has a beefier gear setup as well, it also doesn't have a reverse gear seeing as the ESC does this for you. Also, the E uses stringer drive shafts, and the differentials are made of stringer materials as well. simply put, the T drivetrain can't stand up to the E's torque. It is probably still less expensive for you to by a new or used E and transfer the parts over from your T than to buy the parts indivudually and convert. The new E can be bought from Tower for around $320 including shipping or you can get a used one off e-bay for under $200. Pieced out, to convert your T is as follows.
ESC-$125
Stock Chassis-$18
Pinion gears-$8
2 titan motors-$40
Differential setup F/R-$50
Transmission-$60
Spur gear-$6
That's $307 and still doesn't include everything you will need, so, as you can see, it makes much more economic sense to buy it as a whole and transfer parts. Either way, good luck.
