unscrew until the top of the screw head is level with the spot its sitting in, try that, if its revving high than tighten it (or loosen it, it depends the type of truck, but this is easy to find out, start the truck and what ever way lowers the idle is the way you turn it)
If my reply above doesn't work, try to work with a screw thats under the air intake (filter), theres a little needle valve under there and that controls your idle, as well... becareful with these needle valves, they are delicate if they are screwed in to tight.
I made a little diagram for you.
If this doesn't work, could you give me some pictures of the carb, engine (glowplug in and glowplug out) just to see where the problem is, and maybe even the exhaust cause I had run into a problem where my exhaust was causing a problem, that would be great if you get these pics for me.
