Spur gear size information
Register Log in
Roanoke RC group
RCNT Basher
I know I post here most of the time about gearing problems and questions, I am happy to say my other problems have been fixed! I am here today to ask about spur gear sizes and what the benefit of a smaller spur gear does over a larger pinion gear as I am experimenting with setups on my Volcano EPX. My setup currently is a 2600kv 3660 with 26/64 gearing (pinion recently became a 25t while driving) and I am looking at different spur gears now, so I'd love to know if a smaller spur is better or not and why
tntpoof
RCNT Talkaholic
Taylor Michigan
Bashing, Racing
its about gear ratio.. that is all.. you change gearing to achieve FDR that final drive ratio.us that race try to achieve the MOST outa our electronics.ex. I dont run my esc above 100degree F in summer and keep my batteries just above room temp(15) and my motor never hits 110F...while other push the temp envelope..battery 135 motor 140 esc 120
Roanoke RC group
RCNT Basher
So would it be not much more beneficial to put a smaller spur gear rather than a larger pinion?
olds97_lss
RCNT VIP
Dekalb, IL
Bashing
It's the same really. The difference is when you change the smaller of the two gears, it has a larger impact. Going up or down 1 tooth on the pinion would be like going up or down 2-3 teeth on the spur (depending on the size difference).
Roanoke RC group
RCNT Basher
Ah, I get it. So there are no real pro's and cons between both. Thanks for the help!
olds97_lss
RCNT VIP
Dekalb, IL
Bashing
Not really. Other than the spur changes can be done to get you exactly where you want it, kind of like fine tuning. Change the bell for the broad strokes, then the spur to dial in exactly what you want.
Thread starter Similar threads Forum Replies Date
mattvictor how do different size clutch bells work with stock spur gear Chassis & Drivetrain 4
P savage standard 4.6 ss spur gear and clutch bell size HPI Savage 1
S LST spur gear problem Team Losi LST 9
S Spur and pinion gear question Electric RC 1
Y Traxxas Slash 2WD spur gear is loose Electric RC 6
SlydeeRC Replacing spur gear on kyosho inferno neo 2.0 Nitro RC 2
F Spur gear doesn't reach cluch bell properly Chassis & Drivetrain 17
B Help with Gearing - Rock Rey Spur Gear Electric RC 1
I Losi TenT spur gear help Nitro RC 9
batmanninja losi xxxnt spur gear Chassis & Drivetrain 20
D Stripped Spur Gear Traxxas Revo 7
batmanninja hpi nitro mt clutch/spur gear Chassis & Drivetrain 4
P Steel spur gear? Nitro RC 9
DerekPike HPI Monster King spur gear Chassis & Drivetrain 6
JohnSampson Spur gear destroyed HPI Savage 4
FirsthandSnow Savage XL spur/clutch gear meshing Nitro RC 23
R Spur gear destroying itself Buggy and Truggy 10
pjoseph how to be sure spur gear and clutch bell are aligned square? Traxxas Revo 3
G Robinson 47T GEN3 Slipper Unit Spur Gear Question HPI Savage 0
P Hyper 7 SPUR GEAR HELP Nitro RC 3
Roger A. Cucal Jr. Diff bet 13 & 15 tooth pinion gear w/ 42 spur gear Nitro RC 3
G First Savage spur gear/clutch bell question HPI Savage 1
X Spur gear and bell gear Chassis & Drivetrain 4
B STRIPPING spur gear when revo shifts to 2nd Traxxas Revo 13
T Spur/pinion gear ratios Electric RC 6
pjoseph Should i move spur gear up some? Monster Trucks 9
M Spur gear ?'s Traxxas T-Maxx 10
bobaloohoo T-maxx spur gear lawlz Traxxas T-Maxx 4
M Spur gear HELPMEEE Nitro RC 5
M spur gear Nitro RC 6
P savage spur gear destoryed what new one to get? Nitro RC 10
craig911 savage engine mounts & spur gear HPI Savage 0
Alan81 So the spur gear in my kid's Stampede... Electric RC 6
W Melting spur gear Traxxas T-Maxx 1
Bighomedog11 Spur Gear Problem & Clutch bearings Traxxas T-Maxx 18
H Spur gear HPI Savage 18
H Need help replacing plastic spur gear with metal HPI Savage 2
Huggybear87 Best method to set spur gear mesh Nitro RC 19
Ouchie MTA4 spur gear problem Nitro RC 8
S Revo Spur gear melting Traxxas Revo 4
L savage spur gear/clutch bell issues (video question) Nitro RC 3
T Rustler spur gear Electric RC 14
brunom97 Hpi savage spur gear help HPI Savage 22
N spur gear stripping??? Nitro RC 6
B spur gear Traxxas Revo 5
S spur gear melting HPI Savage 22
S How to set spur gear mesh? HPI Savage 43
C Hpi Savage x 4.6 Steel Spur Gear HPI Savage 2
O Spur gear Problems here. Traxxas T-Maxx 10
I spur gear HPI Savage 4
