Slash 4x4 front end noise
SteveB
Hello,
New to site and RC world.
I have a slash 4x4 that is making a loud noise on the front end when the wheels are on the ground. Sounds fine if you hold it up in the air.
Where should I start?
Welcome! Open up the differential, check the bearings and gears. If the bearings are gritty feeling, or aren’t smooth, or even seized, replace them.
Hello,
Welcome to RCT. We'll like Pug said it's the front diff. Probably have a broken gear. Is it a new slash from the factory?
Welcome to RCTalk and thanks for joining!
If you're new to the RC hobby, we have several very active threads here on RCTalk that could be especially of some help for you to making your start into the hobby much more enjoyable and easier!
Even if you're not new, we would still love to hear your feedback on the tools and electronics you are using in the above threads!
Quick Forum Tips
If you do the social media thing, be sure to like and follow us on Facebook and Twitter!
Premium Membership
Military roll call: Active Duty | Veterans
Have RC News?
Email us here.
Become a Forum Sponsor | Support RCTalk
As mentioned, it may be the diff, ring gear, front pinion, driveshaft, bearings, or axles. Take the wheels off, check the bearing on the outside and inside of the carrier. Remove and check the axles. Take the front bulkhead off and remove the diff. Give the diff bearings a good spin to make sure they spin freely. If the ring and pinion look ok, pull the diff apart and check the spider gears.
It's one of those ☝️
Thank you
Thank you
