Well, since the forum delivered a resounding yes to getting the old tug.. here it is. I'll show you some of the vintage electronics, share a few thoughts on my restoration ideas and a few questions regarding some of the older RX / TX gear.
Purchased and ready to take home.
On the workshop bench. Taking a closer look. Nice Patina.
Top down, needs some dusting and pieces glued back on. maybe some paint and new decals. Thinking some 1/24th crawler tires hanging off the front for a bumper and maybe working that little rope and reel into an actual boat rescue device.
First look at the vintage Dumas mechanical speed controller, a Pittman Panther 3-6 VDC boat motor and the D cell battery holders, to power the Pittman.
Lots of sloppy glue work and old foam throughout. Not much I can do about the glue / epoxy. If doesn't sink, I'll be leaving it as is. I will be pulling out the foam, to take a closer look. You can see the rescue boat jammed in there. That will need to be glued back on to the deck. Any guesses on how old this build is? I'd like to replace the D cells with a 2S lipo. Of course the motor and speed control are rated for 6 volts, so I'll need to reduce the 7.4v with a buck step-down converter. Let me know if anyone has any other ideas.
A look at the Keel, rudder and prop. Prop and rudder both move freely. I really like the shiny red look. I have yet to perform a leak test.
came with this nice wooden stand. It holds the boat perfectly. Can't imagine how I'd work out the boat, without it.
Another look at the DUMAS MOTORS #2002 6 Volt mechanical speed controller. Please share info if you have it. For example, how strict is the 6v rating on this and the motor. See how the builder had it tied in there on the servo board with twine. Is it possible that this was placed in there before zip ties were commonly available? The servos for the mechanical speed control and rudder are both Futaba FP-S28
The Pittman Panther. What a beauty. It took me a minute to get it spinning, using the MDP-M01 bench power supply, but it works. Also, got it running with the speed controller and D cells. My initial thought was to replace all the electronics, but keep the motor. I may go ahead and try to get it running, restoring everything as is. I can always upgrade later, if it doesn't work out.
Inside the speed controller. Wasn't working at first, everything stuck and oxidized. Freed everything up with contact cleaner and dielectric grease, checked fuse and points with a meter. Seems to still be functional. If I can get everything running with the old electrics, this will be my first RC with a mechanical speed controller.
Zip tied back on to the servo board and cleaned out all the old foam. Receiver is an AM FP-R4F. I can't find and info, at all, on this RX. Not even sure how many volts DC, to run it. I slowly ramped up to 3V on the bench supply and got it running. I am nervous to increase it past that point. Anyone know anything about this receiver?
FP-R4F Rudder servo is strong and relatively quick at 3VDC. Same with the servo for the speed controller. There is a switch on the deck of the boat, for the RX that I temporarily wired in. The switch had two confusing wires / connectors hanging off it. One seemed to pass DC, the other.. nothing. In the old days, there was a battery for your motor and another batter for the RX. I'm hoping to run everything in this boat off the 2S lipo, including this Receiver. Not sure exactly how yet. The Buck converter to convert DC 7.4 to 6VDC for the motor and a
BEC (Battery Eliminator Circuit) off of the buck to convert 6VDC to 3VDC for the RX? Let me know your ideas, if you know of a better method. This is the buck converter I ordered. LM317 DC-DC Step Down Converter 4.2-40V in 1.2 to 37V out DC 2Amp
I thought the radio was fried, at first. I took it apart and cleaned up the battery compartment with sand paper and contact cleaner. It is intermittent, but working. Gimbals seem fine and antenna is in tact. 8AA batteries! Geesh! Another first for me, running an RC with an AM radio. Not sure how smart it is in todays congested RF environment. That said, I'll likely be away from any major radio towers when I am running this boat and will likely keep it close to shore.
That's it for now. Hope you enjoy the pics and thank you for motivating me to pick up this cool vintage RC.
