Servo to Bind Plug?
skurtzicus
Hey guys i asked this question on facebook but i feel like i should ask it again before i destroy a servo. On facebook they said chop the wires, remove the middle wire, and connect the negative to the positive. But none of them showed me how they themselves did it , which is something i would like to see so i know I'm not just breaking an old servo for no reason. So if you did it or know someone who did then please let me know. I want to try and get this done when i can, hopefully before my parts arrive.
ok here is how it is done. on a servo to rx plug it has little tabs that hold the garment in. gentle pry that little lock up slide center wire out .. or just buy a servo extension wire ...sorry no pic . now take the 2 wires that are left . pull them apart now strip the ends. slide a piece of heat sink on and solder them together
here in bind 1 pic the tab is silver at end of pointy thang. pry that up. either solder twisted joint or use a piece of gorilla tape make a pull tab
So i fully pull out the red wire then cut and connect the other two, correct?
Thank you so much i got it done and binded but now I'm having other issues. the steering is drive and reverse on my remote and the trigger is left and right(update i just had to switch around the wires). But now the servo goes uncontrollable and tweaks when on. the throttle and reverse work good though
yes correct.
but forreal your the mvp for showing me how to make the bind plug and for that i thank you a lot. Once i get my d3 binded and working I'm going to try set up me sc10 next so i really want to get this done.
yes that does go all over.. id try a glitch buster .its a cap you plug into the rx. if you have a voltage meter id check the esc wires see the voltage.
