appst8design
I recently bought an S-Maxx to kind of get my feet wet with Nitro RC trucks. As you would guess there is not much I know about the trucks but there is a lot I'm finding out. I believe I broke it in the right way per the manual but after what happened maybe not. Last week while starting it I noticed the carburetor had a leak along the fabricated seam so I glued it shut, let it dry, and then started it back up for another run. About a full fuel tank later while using the truck it cut off and stopped dead. I was using the EZ start to try and restart it but the engine wasn't even rolling over so I knew it was a bigger problem. I haven't even run a gallon of fuel yet so this engine failure seems very premature. I'm pretty handy (or some of you may say not really after reading this post... lol) so I started to disassemble the engine and started to find bits of metal. Come to find out the piston arm had shattered and the piston was froze in the piston sleeve. So that being said could this (A) be a result of breaking it in with a busted carburetor which resulted in a lean/rich fuel air mixture resulting in engine failure. (B) me breaking it in wrong in cold temperatures. (C) the engine running at too high of a temperature. (D) something I haven't mentioned.
Any advice would be much appreciated, thanks!
